Date/Time: Fri, 10 Jan 2025 09:15:30 +0000
"Price change" on Compact Tool Values panel
View Count: 729
[2016-08-31 11:46:38] |
chifounou1 - Posts: 13 |
Hello, why the line "Price change" is on the big ChartValues window but not on the Compact Tool Values panel ? Which I much prefer This is a great miss... By the way, love your software. The more I dive into it, the more I find it amazing. Really thought to perfection. Cheers |
[2016-08-31 17:45:42] |
The Compact Tool Values window is meant to contain minimal information. Refer to this page for how you can customize the Chart Values windows and reduce the amount of information displayed to be more like the Compact Tool Values window: http://www.sierrachart.com/index.php?page=doc/helpdetails67.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-08-31 20:00:09] |
Too bad The "Price Chg" is a key element ...besides, the Compact Tool Values I find much more practical to use. I wish you can add the "Price Chg" info as an option to the Compact Tool Values in a future update. Thank you |
