Date/Time: Fri, 10 Jan 2025 08:52:31 +0000
how to set "volume per bar" without starting a new bar from everyday session start?
View Count: 680
[2016-08-31 11:14:43]
User780585 - Posts: 6
I found that my "volume per bar" chart starts a new bar each day from the session start. I would like to have a continuous "volume per bar" chart which does not re-start each day (i.e. the volume at the session start is added into the last bar of the previous day until it reaches the predetermined volume). How can I choose the settings?
[2016-08-31 12:15:41]
TechTrader - Posts: 116
Select > Chart > Chart Settings - on the Main Settings tab uncheck 'New Bar At Session Start'
[2016-08-31 12:52:17]
THX!
