Date/Time: Fri, 10 Jan 2025 09:10:50 +0000
Auto-launch chartbook on startup
View Count: 1174
[2016-08-31 10:18:22] |
chifounou1 - Posts: 13 |
Is there a way ? cheers
[2016-08-31 10:35:22] |
Yes. Refer to: Chartbooks (Workspaces): Automatically Open a Chartbook Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
