Date/Time: Fri, 10 Jan 2025 08:58:30 +0000
more space so that DOM Graph on Chart does not overlay
View Count: 673
[2016-08-31 08:54:23] |
chifounou1 - Posts: 13 |
Hello, when I activate Trade / Draw DOM Graph On Chart the liquidity bars overlay my candle sticks Is there a way to add some extra space on the right of the chart so that it doesn't overlay ? Thanks |
[2016-08-31 10:11:21] |
Yes. Refer to: Working With Charts: Right Side Fill Space Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
