Date/Time: Sat, 26 Sep 2026 22:22:41 +0000
Chart with IQFeed and T&S with IB data feed
View Count: 2268
[2013-07-22 17:31:07]
User30668 - Posts: 108
Hello Support Team,
I have subscribed IQfeed free trial last week and I have been making some testing.
Up to now I’m having just one problem that I can’t figure out the solution:
I have a 2 range chart open in the instance that is connected to my broker (IB) and this chart is sharing the IQFeed data from a remote instance and it is working well.
I have the option “Use non-Chart Data from Remote Instances” not selected, so I think this chart should be receiving all the rest of the data, including T&S, from IB.
When I open a T&S window from this chart, the T&S window appears but without any data. I thought I would get the T&S data from IB in that T&S window.
Is this not possible to do or am I doing anything wrong?
Thanks in advance.
[2013-07-22 17:56:13]
Go to that chart and select Chart >> Chart Settings. What do you have set for "Alternate Real-Time Update Symbol"? It needs to be set to the corresponding Interactive Brokers symbol.
Also, you are running a slightly older version and we recommend updating because this may resolve the problem. To update select Help >> Download Current Version.
Date Time Of Last Edit: 2013-07-22 17:56:37
[2013-07-22 18:46:48]
Ok, it was just that setting "Alternate Real-Time Update Symbol".
It is working now.
Sorry to take your time.
Thanks.
Date Time Of Last Edit: 2013-07-22 18:47:07
[2013-07-23 03:19:06]
joshtrader - Posts: 569
As a side issue, why would you want IB T&S data, which is completely inaccurate, when you have great IQFeed data to run your T&S?
[2013-07-23 14:08:33]
joshtrader,
I am just running some tests for now and comparing the different results.
To answer your question, the inaccurate IB T&S provides some useful information that IQFeed does not provide.
[2013-07-23 14:15:48]
Ok--what useful information?
[2013-07-23 16:53:17]
Answering your question would take me much beyond the scope of this forum.
Do you want me to email you?
