Date/Time: Fri, 10 Jan 2025 09:30:05 +0000
Error in change of slope in MA alert condition
View Count: 726
[2016-08-31 07:36:07] |
User494206 - Posts: 44 |
Dear, I want an alert when the MA change of slope. I have copied the condition from the sierra chart website, but it is not working: =OR(AND(SG1[0] > SG1[-1],SG1[-1] < SG1[-2]),AND(SG1[0] < SG1[-1],SG1[-1] > SG1[-2])) Can you help me? Thanks |
[2016-08-31 10:13:14] |
We have too little information to know what the problem is. It may be a problem with the Value Format setting: https://www.sierrachart.com/index.php?page=doc/StudyChartAlertsAndScanning.php#ValueFormat Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-09-01 17:06:10] |
The Ma that haas to give an alert, is a MA on a MA. Maybe you can help me now?
[2016-09-01 20:34:37] |
We will need to get a Chartbook from you containing a single chart containing a study containing this formula. Here are instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
