Date/Time: Fri, 10 Jan 2025 09:52:47 +0000
Price APPLE
View Count: 1220
[2016-08-30 20:39:38]
User67846 - Posts: 3
I note some difference between sierra price and nasdaq price for ex. apple stock
07.26.2016 sierra open 96,298 high 97,442 low 95,90 close 96,149
nasdaq site open 96,82 high 97,97 low 96,42 close 96,67
07.27.2016 sierra open 103,698 high 103,788 low 102,196 close 102,395
nasdaq site open 104,265 high 104,35 low 102,75 close 102,95
Can you explain the reason.
Regards.
[2016-08-31 02:04:59]
Those are not the values we see. We checked both of those dates and we see these values:
Re-download the data with Edit >>Delete All Data and Download.
[2016-08-31 16:28:29]
I did edit>>delete all data and download this is the screen:
http://www.sierrachart.com/image.php?Image=1472660475707.png
In attached files you can see nyse quote for apple the difference persist
Regards
attachmentNYSE.pdf - Attached On 2016-08-31 16:23:25 UTC - Size: 580.69 KB - 314 views
[2016-08-31 17:42:52]
Make sure that Global Settings >> Data/Trade Service Settings >>Download Dividend Adjusted Historical Data is disabled.
After changing that option, re-download the data in the chart and let us know if you see the correct values.
[2016-08-31 18:30:08]
Now it match perfectly thank you
[2016-09-01 06:50:30]
Here is the relevant documentation for this:
http://www.sierrachart.com/index.php?page=doc/helpdetails12.html#h12.11
