Date/Time: Fri, 10 Jan 2025 10:05:25 +0000
include title bar when saving chart image
View Count: 907
[2016-08-30 19:38:04] |
User565364 - Posts: 10 |
Hello, when I save chart image, I would like to include title bar. When I do Edit-Screen Image, title bar is not included in the saved chart image. Is there a way to make title bar part of the image saved? Here's an example: http://www.sierrachart.com/image.php?Image=1472582087462.png Thanks |
[2016-08-30 19:46:55] |
There is not a way to include the title bar, but it looks like you have hidden the Region Data Line. Refer to this section about this: http://www.sierrachart.com/index.php?page=doc/helpdetails67.html#HidingRegionDataLines You need to unhide it. Once that is done you will want to add the fields that you want to display to the chart header: http://www.sierrachart.com/index.php?page=doc/GlobalSettingsMenu.html#CustomizeChartHeader Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-08-30 19:56:03] |
Thank you, I unhide the region lines as suggested and it somewhat works. Here's how the chart looks like now http://www.sierrachart.com/image.php?Image=1472586871508.png Finally how do I remove the dark grey box on the top left corner? |
[2016-08-30 21:45:41] |
To remove the chart trade mode box , uncheck Trade >>Chart Trade Mode On.
[2016-09-01 00:24:16] |
one last thing: what is the little green box on the bottom right corner that says "6L". How do I remove it? thank you! |
[2016-09-01 01:00:32] |
Refer to: https://www.sierrachart.com/index.php?page=doc/WorkingWithCharts.html#LRChartSettingsIndicators It is not removable. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
