Date/Time: Fri, 10 Jan 2025 09:09:29 +0000
ES-201609 data feed busted
View Count: 650
[2016-08-30 11:39:14] |
Bluefruit - Posts: 41 |
CanĀ“t retrieve chart for the ES-201609 symbol. Only few bars uploaded. The NQ and YM symbols work properly. ES http://www.sierrachart.com/image.php?Image=1472556991611.png NQ http://www.sierrachart.com/image.php?Image=1472557094631.png YM http://www.sierrachart.com/image.php?Image=147255712811.png |
[2016-08-30 14:14:56] |
This looks like a missing data problem. Refer to the instructions here: http://www.sierrachart.com/index.php?page=doc/HistoricalIntradayData.html#RetryDownloadDataInChart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-08-30 14:55:22] |
Thank you guys.
