Date/Time: Fri, 10 Jan 2025 14:35:00 +0000
MJNK Mini-Nikkei 225
View Count: 2064
[2016-08-30 03:24:25] |
User144295 - Posts: 70 |
Hi Support Team, I reviewed this post: Osaka Nikkei 225 Mini where you advise traders to use CQG to get historical data for MJNK Mini-Nikkei 225. I hope I have not missed anything, but is there a chance to actually have real time data and trade it through CQG or ideally SC Real Time Data (which I use)? Thank you |
[2016-08-30 05:31:08] |
For real-time and historical data and to trade that particular market, you do need to use CQG. That market is tradable through CQG.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-08-30 05:31:44
[2016-09-18 01:47:36] |
Hi, I browsed their website and I wasn't sure about one thing. If I go with CQG, they seems to offer their own platform for trading MJNK Mini-Nikkei 225. But in case I want to use Sierra Chart usage time using my Sierra login, can I do it with combination with CQG? Also next question coming up from this is: Does it mean I do not need Sierra Chart real time data anymore and CQG will provide me with their data feed with combination of Sierra Chart software usage time? Thank you
[2016-09-18 02:35:27] |
Yes you can.Does it mean I do not need Sierra Chart real time data anymore and CQG will provide me with their data feed with combination of Sierra Chart software usage time?
Yes this is correct.
