Date/Time: Fri, 10 Jan 2025 09:00:07 +0000
shading two areas (fill) in study
View Count: 942
[2016-08-29 18:51:43] |
User316362 - Posts: 210 |
I have a simple study with an oscillating Line. there is also a high level and low level price(other other) horizontal lines used as thresholds. I want to fill/shade the area between the line and the upper threshold (when above) and lower threshold (when below). I can use fill-top/fill-bottom to get one of the areas to shade but not both. Is there a way to do this in the study or better yest in ACSIL (an example study might suffice)? |
[2016-08-29 21:46:53] |
You will need to add 2 instances of the study to the chart to do the type of fill that you require. One instance would fill to the upper threshold and the other instance to the lower threshold. For more information, refer to: http://www.sierrachart.com/index.php?page=doc/ChartStudies.html#FillingArea Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
