Date/Time: Thu, 19 Sep 2024 21:38:38 +0000
Trade Dom has position when there is none
View Count: 1439
[2013-07-22 15:19:32] |
trader1 - Posts: 128 |
If the trade dom shows a position that does not exist how do I remove it?
[2013-07-22 16:28:20] |
If you see the position listed on Trade >> Trade Orders and Positions >> Positions, then follow the instructions here to remove it: https://www.sierrachart.com/index.php?l=doc/doc_TradeStatusWindows.html#ResetInternalPositonForSymbol Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
