Date/Time: Fri, 10 Jan 2025 08:45:20 +0000
label cutoff
View Count: 638
[2016-08-28 23:25:33] |
aydex - Posts: 110 |
after adding a stop-limit setting, seeing the cancel x cutoff is there a way of shifting to the left, without reducing the font size |
Capture.PNG / V - Attached On 2016-08-28 23:25:02 UTC - Size: 9.79 KB - 227 views |
[2016-08-29 00:57:01] |
We are looking into this.
[2016-08-29 23:31:57] |
This will be improved upon in the next release.
