Date/Time: Fri, 10 Jan 2025 08:51:41 +0000
Renko charts
View Count: 743
[2016-08-28 22:54:56] |
madra - Posts: 109 |
Hello, i have set the tick size 50 and the bar size 50. The bar size shows 4 at the top of the chart below the list of chartbook. When I check the chart display measuring the bar size it shows the brick size as 4 ticks. How do I cause the bar size to be the size i enter in the setting box? Thank you |
[2016-08-28 23:03:33] |
This is not making sense to us. We have no context. Provide an image of the chart, by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-08-29 01:40:02] |
http://www.sierrachart.com/image.php?Image=1472434321450.png
[2016-08-29 01:51:04] |
Select Chart >> Chart Settings. What is the Tick Size set to? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-08-29 21:58:55
[2016-08-29 03:01:52] |
price display format .01 tick size 0.01 Here is another screen shot of another symbol. the brick size is not uniform http://www.sierrachart.com/image.php?Image=1472439515213.png |
[2016-08-29 22:04:17] |
In regards to the chart in post #3, what do you want to the brick/body size to be as an actual value? In regards to the chart in post #5, disable this option: http://www.sierrachart.com/index.php?page=doc/ChartSettings.html#NewBarSessionStart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-08-30 05:17:30
[2016-08-30 05:17:42] |
We need to make a correction. In regards to the chart in post #5, disable this option: http://www.sierrachart.com/index.php?page=doc/ChartSettings.html#NewBarSessionStart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
