Date/Time: Sun, 27 Sep 2026 21:44:09 +0000
ASCIL access to symbol's Round Trip Commission
View Count: 2567
[2016-08-28 11:26:02]
DabbaDo - Posts: 150
I can't find a way for my study to access this global symbol commission setting, unless/until it appears on a trade. Am I just missing something simple?
Thank you.
[2016-08-28 22:37:49]
This is the ACSIL member for this:
sc.RoundTurnCommission
[2016-09-02 18:02:43]
No matter what I do, sc.RoundTurnCommission is always 0.
E.g. I have a study on a chart of F.US.EPU16.
I go to Chart Settings then "Edit Global Symbol Settings"
That takes me to Global Symbol Settings for CQG FIX Trading for F.US.EP?##
On the Additional tab my Round Turn Commission is 4.25
But in the debugger sc.RoundTurnCommission is always 0.
Thanks,
Dale
[2016-09-02 18:10:29]
After you set the Round Turn Commission, then you will need to close the Chartbook and reopen it. Refer to:
http://www.sierrachart.com/index.php?page=doc/Chartbooks.html
[2016-09-10 17:01:50]
I still can't get a Round Turn commission to be non-zero in a study. I've tried with a stock (IBM) and a futures symbol (ESZ16). I add the Round Turn Commission on the Internal table per http://www.sierrachart.com/index.php?page=doc/GlobalSymbolSettings.php. I close the chartbook and re-open it. Nothing I do get's me to a non-zero value. Short study example:
#include "sierrachart.h"
SCSFExport scsf_TestCommission(SCStudyGraphRef sc)
  int& isMessageLogged = sc.GetPersistentInt(1);
  if (sc.SetDefaults)
    sc.GraphName = "Test Commission";
    return;
  if (!isMessageLogged)
    SCString message;
    message.Format("For symbol=%s RoundTurnCommission=%f", sc.Symbol.GetChars(), sc.RoundTurnCommission);
    sc.AddMessageToLog(message, 1);
    isMessageLogged = 1;
    sc.SetPersistentInt(1, isMessageLogged);
[2016-09-10 22:32:27]
We are looking into this now.
[2016-09-10 22:44:24]
We know why this is now happening. This will be solved in the next release.
[2017-02-10 08:37:07]
This is happening to me again in 1510, using the same test code shown above. With ESH7 (connected to Gain) sc.RoundTurnCommission is always 0. But with ESH17 (connected to SC Data - All Services) sc.RoundTurnCommission reports the commission properly (as set in Edit Global Symbols).
In my GlobalSymbolSettings.xml I have these:
<settings>
    <service-code>scdataallservices</service-code>
    <symbol>ES?##</symbol>
    <use-pattern-matching-characters>true</use-pattern-matching-characters>
    <contract-months>HMUZ</contract-months>
    <description>E-Mini S&P 500 Index (ES) - GBLX</description>
    <category>Futures - Indices</category>
    <value-format-code>2</value-format-code>
    <tick-size>0.25</tick-size>
    <currency-value-per-tick>12.5</currency-value-per-tick>
    <error-filtering>true</error-filtering>
    <time-zone>EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00</time-zone>
    <intraday-start-time>16:15:00</intraday-start-time>
    <intraday-stop-time>16:14:59</intraday-stop-time>
    <default-order-quantity>1</default-order-quantity>
    <rt-commission>4.08</rt-commission>
    <rollover-method>Method3</rollover-method>
    <rollover-input-1>8</rollover-input-1>
    <rollover-input-2>3</rollover-input-2>
    <sc-data-symbol>ES?##</sc-data-symbol>
    <sc-data-symbol-multiplier>0.01</sc-data-symbol-multiplier>
    <sc-data-srvcode>cme</sc-data-srvcode>
  </settings>
<settings>
    <service-code>DTCSubInstance</service-code>
    <symbol>ES?#</symbol>
    <historical-chart-symbol>ES?##</historical-chart-symbol>
    <description>E-mini S&P 500 - CME</description>
    <category>Futures</category>
    <use-patch-data>true</use-patch-data>
    <patch-data-source>cme</patch-data-source>
    <patch-data-symbol>ES?##</patch-data-symbol>
    <patch-data-multiplier>0.01</patch-data-multiplier>
    <patch-data-use-sc-exchange-data-servers>true</patch-data-use-sc-exchange-data-servers>
    <maintain-server-data-service-codes>oec,scoec</maintain-server-data-service-codes>
  </settings>
[2017-02-10 18:05:17]
In the instance of Sierra Chart you are noticing this with, go to Global Settings >> Symbol Settings.
For the ES?# symbol, is there a Round Turn Commission set?
[2017-02-10 18:13:36]
Yes.
But the problem has disappeared. I was having troubles with debugging this instance, so I rebooted my PC.
Now the test works on this instance!
Sorry to bother you.
I blame M$oft. :)
Cheers,
Dale
[2017-02-10 18:25:17]
OK if you have the issue, it does not matter to us what the XML file shows for symbol settings because from our perspective we cannot correlate that to the problem you are having.
We have to know what you see in Global Settings >> Symbol Settings for the current service.
