Date/Time: Fri, 10 Jan 2025 09:03:05 +0000
Where is the message log saved file?
View Count: 1334
[2016-08-28 10:58:31] |
idcisosf - Posts: 34 |
Ok, Once I enabled Save Message Log to File, then where can I find them? Where can I find the message log saved in the past? The Help topic: The Message Log files are saved in the Logs subfolder in the folder that Sierra Chart is installed to on your system. So, can you show me where is the Logs subfolders? Thank you, Frank |
[2016-08-28 20:44:55] |
Log into this Support Board with your Sierra Chart account with Help >> Support Board within Sierra Chart and let us know when that is done.
[2016-08-29 02:12:22] |
It's done. Ok, Once I enabled Save Message Log to File, then where can I find them? Where can I find the message log saved in the past? The Help topic: The Message Log files are saved in the Logs subfolder in the folder that Sierra Chart is installed to on your system. So, can you show me where is the Logs subfolders? Thank you, Frank |
[2016-08-29 22:06:06] |
This account you have logged into the Support Board with is expired. What do you see for Account Name when you select Help >> About. You are still not logged into the correct account. The default location for the logs folder is: C:\SierraChart\Logs Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
