Date/Time: Fri, 10 Jan 2025 03:37:58 +0000
[Programming Help] - Chart bar Index
View Count: 1309
[2016-08-27 18:30:06] |
User382358 - Posts: 2 |
I need to get the chart bar Index to count the no. of bars in the chart. I see that sc.Index does not work. Eg: If (Buy) myIndex = sc.Index ; If (EndBuy) no_of_bars = sc.Index - myIndex ; sc.Index is auto incremented and points to current bar. Is there a way to get the Index / count the no. of bars based on a condition ? thanks |
[2016-08-28 00:26:43] |
What you are doing looks correct. Just make sure that myIndex is persistent between function calls: ACSIL Programming Concepts: Global Variables Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-08-29 17:37:54] |
I am not using any new functions other than calling standard study ( RSI, moving average, etc..). I see that the values for no_of_bars remain zero when used. int myIndex, no_of_bars; If (Buy) myIndex = sc.Index ; If (EndBuy) no_of_bars = sc.Index - myIndex ; What is required here ? thanks |
[2016-08-29 19:02:10] |
We do not provide programming help. You need to figure this out on your own because we do not provide programming help and what you are doing wrong is not clear from this code. This page may be helpful: Working with ACSIL Arrays and Understanding Looping Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-08-29 19:02:57
