Date/Time: Fri, 10 Jan 2025 03:38:04 +0000
Error after Update to 1452 or higher
View Count: 1158
[2016-08-27 16:45:06]
Paul.M - Posts: 113
Hi Sierra team,
We attempted a Sierra update to the current version on one of our older machines.
First,
the installer warns that the Install-Folder is not the standard Program Files Folder.
We have a German localization. Sierra is in an individual folder within our standard "Programme" folder.
Second,
after the installer is finished The new Sierra will not start and gives the error:
"SierraChart.exe ist keine zulässige Win32-Anwendung"
translation: ~ "SierraChart.exe is not a valid Win32-Application"
Sierra will not start.
For now I downgraded to 1488 and Sierra runs again nicely.
TY
Date Time Of Last Edit: 2016-08-27 16:46:18
[2016-08-27 23:41:17]
We started to use a new Microsoft compiler and are having trouble with Windows XP support.
We will probably have to create a custom build for this but it is not going to be frequently updated. Probably only a few times a year. For now use version 1448 or earlier.
[2016-08-29 11:06:49]
User742717 Mike - Posts: 86
EDIT: please disregard, just realised its version 1448
Hi
I'm on linux and use a winXP virtual machine, it's small, lite and works well with SC.
I tried 'upgrading' to 1488 but there's a problem not finding the path, see the log below.
Installer version: 6 | 2016-08-29 06:02:18
Not using proxy server settings. | 2016-08-29 06:02:30
HTTP Request: https://www.sierrachart.com/downloads/1488/FilesToDownload.txt | 2016-08-29 06:02:30
HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-08-29 06:02:30
HTTPS connection to www.sierrachart.com:443 (1) | Connected. | 2016-08-29 06:02:30
HTTPS connection to www.sierrachart.com:443 (1) | Starting TLS 1.2 connection. | 2016-08-29 06:02:30
HTTPS connection to www.sierrachart.com:443 (1) | SSL connection established. | 2016-08-29 06:02:31
Incorrect URL when trying to get files list to download. | 2016-08-29 06:02:32
HTTPS connection to www.sierrachart.com:443 (1) | SSL connection closed by remote side. | 2016-08-29 06:02:37
HTTPS connection to www.sierrachart.com:443 (1) | Connection gracefully closed by remote side. | 2016-08-29 06:02:37
HTTPS connection to www.sierrachart.com:443 (1) | SSL object has been freed. SSL state is now disconnected. | 2016-08-29 06:02:37
HTTPS connection to www.sierrachart.com:443 (1) | Shutdown and closed. | 2016-08-29 06:02:37
HTTP Request: https://www.sierrachart.com/downloads/1488/FilesToDownload.txt | 2016-08-29 06:02:37
HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-08-29 06:02:45
HTTPS connection to www.sierrachart.com:443 (2) | Connected. | 2016-08-29 06:02:45
HTTPS connection to www.sierrachart.com:443 (2) | Starting TLS 1.2 connection. | 2016-08-29 06:02:45
HTTPS connection to www.sierrachart.com:443 (2) | SSL connection established. | 2016-08-29 06:02:46
Incorrect URL when trying to get files list to download. | 2016-08-29 06:02:46
HTTPS connection to www.sierrachart.com:443 (2) | SSL connection closed by remote side. | 2016-08-29 06:02:51
HTTPS connection to www.sierrachart.com:443 (2) | Connection gracefully closed by remote side. | 2016-08-29 06:02:51
HTTPS connection to www.sierrachart.com:443 (2) | SSL object has been freed. SSL state is now disconnected. | 2016-08-29 06:02:51
HTTPS connection to www.sierrachart.com:443 (2) | Shutdown and closed. | 2016-08-29 06:02:51
HTTP Request: https://www.sierrachart.com/downloads/1488/FilesToDownload.txt | 2016-08-29 06:02:51
HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-08-29 06:02:51
HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2016-08-29 06:02:52
HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2016-08-29 06:02:52
HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2016-08-29 06:02:53
Incorrect URL when trying to get files list to download. | 2016-08-29 06:02:53
Maximum number of retries encountered. Refer to log. Download canceled. | 2016-08-29 06:02:53
HTTPS connection to www.sierrachart.com:443 (3) | SSL shutdown indicates not able to send 'close notify'. | 2016-08-29 06:02:57
HTTPS connection to www.sierrachart.com:443 (3) | SSL has been shut down. | 2016-08-29 06:02:57
HTTPS connection to www.sierrachart.com:443 (3) | SSL object has been freed. SSL state is now disconnected. | 2016-08-29 06:02:57
HTTPS connection to www.sierrachart.com:443 (3) | Shutdown and closed. | 2016-08-29 06:02:57
Date Time Of Last Edit: 2016-08-29 11:11:03
