Date/Time: Fri, 10 Jan 2025 03:58:25 +0000
Unable to connect issue. The log is included below.
View Count: 686
[2016-08-27 13:08:13] |
User600819 - Posts: 43 |
CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2016-08-27 09:03:28 CTS T4 FIX | Firm: PTP | 2016-08-27 09:03:28 CTS FIX socket (0) | Resolved address fix-sim.t4login.com to IP 74.201.6.199. | 2016-08-27 09:03:28 CTS FIX socket (11) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-08-27 09:03:29 CTS FIX socket (11) | Shutdown and closed. | 2016-08-27 09:03:29 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2016-08-27 09:03:29 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-08-27 09:03:29 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-08-27 09:03:29 CTS T4 FIX | Disconnected. | 2016-08-27 09:03:29 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-08-27 09:03:29 File >> Disconnect selected. | 2016-08-27 09:03:31 CTS T4 FIX | Disconnected. | 2016-08-27 09:03:31 |
[2016-08-27 18:55:02] |
The CTS server is unavailable at this time.
