Date/Time: Fri, 10 Jan 2025 04:07:58 +0000
How do you move the location of the 'Backups' Folder
View Count: 766
[2016-08-26 21:06:49] |
Adam - Posts: 141 |
i would like this folder C:\SierraChart\Backups sent to a another drive on my PC such as D:\ which is sync'd with Dropbox to have an offsite copy This function seems to be there for the C:\Sierrachart\Data which i have offloaded to D:\ but i cant find how to offload the backups folder. Thanks Adam Date Time Of Last Edit: 2016-08-26 21:12:23
[2016-08-26 22:45:28] |
This cannot be changed but you could write a commandline batch file to automatically copy the files to another drive or folder. You could even run that batch file from a Windows Scheduled Task periodically.
