Date/Time: Fri, 10 Jan 2025 03:38:41 +0000
Issue with charts and data
View Count: 715
[2016-08-26 14:40:48] |
dc2uh - Posts: 25 |
I signed up for the active data feed and then also the cme package and have restarted multiple times but nothing is happening! When i open the charts it says symbol unknown and then also the charts don't do anything. Please help
[2016-08-26 16:40:50] |
So it sounds like the problem is the charts do not update in real-time? Who is your futures broker? For the reason why we ask this question, refer to: http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#UnderstandingAccessingDataFromCME Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-08-26 16:41:33
[2016-08-26 16:41:45] |
The prior post has been updated. This was the link we meant to provide: http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#UnderstandingAccessingDataFromCME Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-08-26 19:12:44] |
dc2uh - Posts: 25 |
I use tradestation..am i going to have to change that?
[2016-08-26 21:08:18] |
If you want to pay the lower-priced 15 USD exchange fee for the CME Group, you will need to have a trading account with a supported futures trading service. You could open an account with 1000 with one of them: https://www.sierrachart.com/index.php?page=doc/links.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-08-27 18:43:58
