Date/Time: Fri, 10 Jan 2025 03:53:34 +0000
ribbon like trend indicator
View Count: 1625
[2016-08-26 01:37:48] |
User970210 - Posts: 87 |
Hi, I am wondering how I can overlay two color trend ribbon in same pane but not overlapping to each other. thanks in advance. Song |
temp 1.gif / V - Attached On 2016-08-26 01:36:16 UTC - Size: 126.25 KB - 749 views temp 2.gif / V - Attached On 2016-08-26 01:36:31 UTC - Size: 31.21 KB - 397 views Attachment Deleted. |
[2016-08-26 04:17:07] |
Not sure what you are trying to show in those images. Here is the proper way to attach a chart image: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image If you do not want to studies to overlap each other, they do need to be in different Chart Regions: Chart Studies: Settings and Inputs Tab >> Chart Region Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
