Date/Time: Fri, 10 Jan 2025 03:50:26 +0000
Simulation Trading P/L daily accumulation
View Count: 770
[2016-08-26 00:58:28] |
User493842 - Posts: 22 |
Hi, Is there a setting to make the P&L accumulate each trade? Mine keeps returning to $0. Thanks |
[2016-08-26 04:01:10] |
The Daily Profit/Loss value does accumulate during the trading day. If it does not, then refer to: Help With Daily Profit/Loss Value Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
