Date/Time: Fri, 10 Jan 2025 03:47:05 +0000
Good brooker with CQG data...
View Count: 685
[2016-08-25 20:27:57] |
User60579 - Posts: 41 |
I need to open a small account with a brooker so I can buy CQG data feed to Sierra Charts. I dont plan to trade from the account... Can anyone recommend a good broker for this purpose? Cheers |
[2016-08-26 03:51:47] |
We ourselves do not recommend brokers but you can find a list here: https://www.sierrachart.com/index.php?page=doc/links.php#Brokers Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
