Date/Time: Fri, 10 Jan 2025 03:36:54 +0000
Tick size on crude November crude
View Count: 1140
[2016-08-25 20:09:43]
User610117 - Posts: 40
What is the quickest way to reset a symbol?
November Crude tick value is 2.5 cents vs 1 cent
[2016-08-25 20:56:29]
Are you referring to the Tick Size or Currency Value Per Tick? The Currency Value Per Tick for NYMEX crude oil futures is 10.
Refer to:
Chart Settings: Tick Size (Chart >> Chart Settings >> Symbol >> Symbol Settings menu)
[2016-08-25 23:43:49]
My trading DOM does not show 1 cent increments. It is showing 2.5 cent increments. How do I change this? Shouldn't it automatically show 1 cent increments since this is how the exchange trades it?
Thanks for your help!
[2016-08-26 02:41:34]
PLEASE CLOSE THIS THREAD. ALREADY FIGURED OUT PROBLEM. THANKS!
[2016-08-26 02:48:16]
For reference, refer to:
The Chart DOM Scale: Auto Scale the Chart DOM
