Date/Time: Sat, 11 Jan 2025 09:43:17 +0000
CME Market By Orders changes (MBO)
View Count: 2121
[2016-08-25 19:56:51]
Adam - Posts: 141
Can you tell me if SC will be supporting the new CME MBO
Attached is the UK CME forum held in spring, can you look at slides 22-26 (also PDF pages 22-26)
A) the additional ladder data
B) the additional order information (queue position and quantity in-front)
CME have confirmed they are going live 12th September 2016
Thanks Adam
attachmentlondon-customer-forum-2016-q2.pdf - Attached On 2016-08-25 19:54:19 UTC - Size: 1.87 MB - 1564 views
[2016-08-26 00:12:50]
Yes it will be provided only with the Sierra Chart Exchange Data Feed and no other data feed.
We expect to get to it sometime next year.
[2016-11-22 21:50:53]
Adam - Posts: 141
Hi
As this will be live now for COMEX dec 4th and NYMEX jan 8th. So SC have a more detailed roll out plan?
Are there any test connections within SC data feed?
Adam
[2016-11-23 04:38:58]
We are not going to be able to work on this until sometime next year.
And there is no detailed plan at this time.
The main problem is how should the data be displayed because there can be obviously a large number of orders. So there has to be some method of consolidation.
There is no test connection, but you can use the DTC Protocol Server:
Data and Trading Communications (DTC) Protocol Server
