Date/Time: Fri, 10 Jan 2025 04:00:05 +0000
Quetion...
View Count: 750
[2016-08-25 19:46:43] |
User292365 - Posts: 20 |
Hello, I figured it would be easier to attach an image of my question rather than say it. Looking forward to your reply. I've used FXCM, Etrade, Scottrade, Ninja Trader and MT4. So far Sierra is by far the best trading platform I've used. Too bad I cannot do Forex with Sierra, that would've been great. Keep up the great work! |
Attachment Deleted. Image 4 Sierra.png / V - Attached On 2016-08-25 19:44:32 UTC - Size: 48.15 KB - 255 views |
[2016-08-26 10:20:53] |
You can certainly chart forex symbols. Are you referring to trading Forex? You can do that through Interactive Brokers or LMAX. Or even FXCM with a larger account. Refer to: https://www.sierrachart.com/index.php?page=doc/Data.php Regarding the request, we will see about adding a list box to select a particular active tool configuration for a Tool Configuration window. This is not particularly hard to do so it can be done in the near term. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
