Date/Time: Fri, 10 Jan 2025 04:04:01 +0000
VWAP std deviation lines show only for band 1
View Count: 818
[2016-08-25 17:55:54]
bala - Posts: 74
There are many bands of std deviation for the VWAP, only one band shows on the screen. This even after adjusting the values to make sure they are not off from the range. Also there is NO line defining menu for each line as the documentation says
[2016-08-26 10:16:31]
You need to make sure that the Subgraphs for them are set to a visible draw style. This is documented here in the documentation for the study:
https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s108
This is not clear for us. What specific documentation are you referring to?
[2016-08-26 13:11:06]
bala - Posts: 74
Awesome customer support ! The mistake was mine and I didn't set up the subgraph regions (its my job to read the documentation). I would subscribe to this product simply for the customer support!!!
Thanks,
Bala
