Date/Time: Fri, 10 Jan 2025 04:02:37 +0000
Connection with IB does not work
View Count: 839
[2016-08-25 13:54:58]
User58159 - Posts: 62
My computer today, just a few seconds before opening exchange hours, did something wrong (connection was lost). Since then I can not connect Sierra with Interactive Broker portal. Please, advice as soon as possible ..
Reading Internal Order ID file. | 2016-08-25 08:49:20
Reading Trade Orders file. | 2016-08-25 08:49:20
Reading Trade Positions file. | 2016-08-25 08:49:20
Mapping NQ-201509-GLOBEX to NQU15. Service code: cme | 2016-08-25 08:49:20
Mapping YM-201509-ECBOT to YMU15. Service code: cbot | 2016-08-25 08:49:20
Mapping ES-201509-GLOBEX to ESU15. Service code: cme | 2016-08-25 08:49:20
Mapping EMD-201509-GLOBEX to EMDU15. Service code: cme | 2016-08-25 08:49:20
Software version: 1455 | 2016-08-25 08:49:20
Uses New Spreadsheets | 2016-08-25 08:49:20
Usage end date: 2017-10-06 | 2016-08-25 08:49:20
Enabled for: Advanced Features. | 2016-08-25 08:49:20
Enabled for: Advanced Features 2. | 2016-08-25 08:49:20
Enabled for: Sierra Chart Historical Data Service. | 2016-08-25 08:49:20
Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2016-08-25 08:49:20
Enabled for: INDEXES_DATA_BARCHART | 2016-08-25 08:49:20
Enabled for: CME (Trading Account Required) | 2016-08-25 08:49:20
Enabled for: CBOT (Trading Account Required) | 2016-08-25 08:49:20
Enabled for: COMEX (Trading Account Required) | 2016-08-25 08:49:20
Enabled for: NYMEX (Trading Account Required) | 2016-08-25 08:49:20
Received 1 data feed usernames. | 2016-08-25 08:49:20
Allow Support for Sierra Chart Data Feeds is enabled. | 2016-08-25 08:49:20
Current selected Data/Trading service: Interactive Brokers | 2016-08-25 08:49:20
Chart Update Interval: 500 | 2016-08-25 08:49:20
Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2016-08-25 08:49:20
2016-08-25 08:49:24 Local computer time | 2016-08-25 08:49:20
2016-08-25 13:49:24 Local computer time in UTC | 2016-08-25 08:49:20
2016-08-25 08:49:24 Local computer time in SC Time Zone | 2016-08-25 08:49:20
2016-08-25 13:49:24 Server time in UTC | 2016-08-25 08:49:20
Local computer UTC time and Server UTC time difference: 0 seconds. | 2016-08-25 08:49:20
Program path: C:\SierraChart_IB\ | 2016-08-25 08:49:20
Data Files path: C:\SierraChart_IB\Data\ | 2016-08-25 08:49:20
OS Version Number: 6.2 | 2016-08-25 08:49:20
Locale Setting: C | 2016-08-25 08:49:20
Checking for new symbol settings for ib | 2016-08-25 08:49:20
HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-08-25 08:49:20
HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2016-08-25 08:49:20
HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2016-08-25 08:49:20
HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2016-08-25 08:49:20
Requesting symbol settings for ib. Overwrite = on. | 2016-08-25 08:49:20
Symbol settings received. | 2016-08-25 08:49:20
Processed received symbol settings | 2016-08-25 08:49:20
HTTPS connection to www.sierrachart.com:443 (3) | SSL connection closed by remote side. | 2016-08-25 08:49:30
HTTPS connection to www.sierrachart.com:443 (3) | Connection gracefully closed by remote side. | 2016-08-25 08:49:30
HTTPS connection to www.sierrachart.com:443 (3) | SSL object has been freed. SSL state is now disconnected. | 2016-08-25 08:49:30
HTTPS connection to www.sierrachart.com:443 (3) | Shutdown and closed. | 2016-08-25 08:49:30
[2016-08-25 14:20:58]
Would you like me to send you a Message log for chclking the problem?
[2016-08-25 16:27:58]
Sierra Chart - Max - Posts: 5778
Please provide us the full message log by following these instructions:
http://www.sierrachart.com/index.php?l=PostingInformation.php#MessageLog
Sierra Chart Support
[2016-08-25 16:42:57]
From what we can tell in this Message Log you did not connect to the data feed. Connect with File >> Connect to Data Feed.
If you have not already done so follow through the Interactive Brokers setup instructions:
http://www.sierrachart.com/index.php?page=doc/InteractiveBrokers.php#SetupInstructions
