Date/Time: Fri, 10 Jan 2025 03:36:24 +0000
[Programming Help] - how to read the date time from the listtradeorders xml
View Count: 780
[2016-08-25 00:39:36]
User289438 - Posts: 1
How to read the date time from the xml in the listtradeorders xml
<EntryDateTime>42606.993491539353272</EntryDateTime>
What is the current unit it is in. ould you tell what it means please.
[2016-08-25 02:22:19]
This is a double precision number. You need to use the /ACS_Source/SCDateTime.h header file provided with Sierra Chart.
Here is an example:
double NumberFromFile =42606.993491539353272;
SCDateTime DateTime(NumberFromFile);
//Use the member functions on DateTime to accomplish what you need.
For documentation, refer to:
http://www.sierrachart.com/index.php?page=doc/SCDateTime.html
