Date/Time: Fri, 10 Jan 2025 03:51:26 +0000
sc.GraphDrawType doesn't change for Renko bars
View Count: 850
[2016-08-25 00:19:02] |
SantiagoTrader - Posts: 11 |
It seems that the GDT_RENKO_WICK is being ignored when setting sc.GraphDrawType. Setting sc.RenkoTicksPerBar does work and successfully changes the bar size. However, the chart will still draw GDT_CANDLESTICK unless I manually change the chart type from the Chart -> Graph Draw Types menu. I'm using SC version 1455. |
[2016-08-25 05:53:09] |
We have to test this.
[2016-08-26 23:34:51] |
You need to use this: sc.BaseGraphGraphDrawType = GDT_RENKO_WICK;
[2016-08-27 04:26:11] |
Marvelous, thank you.
