Date/Time: Fri, 10 Jan 2025 03:36:34 +0000
show orders and position
View Count: 731
[2016-08-24 20:37:36] |
User212756 - Posts: 2 |
I use AT charts with Infinity. Although show orders and position is checked, the appropriate lines do not appear on the chart. Please help.
[2016-08-24 20:50:58] |
Refer to: http://www.sierrachart.com/index.php?page=doc/TransAct.php#Trading http://www.sierrachart.com/index.php?page=doc/ChartTrading.html#ViewingOrdersOnTheChart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
