Date/Time: Fri, 10 Jan 2025 04:15:01 +0000
Colors - child order lines
View Count: 1257
[2016-08-24 18:43:50] |
User32722 - Posts: 10 |
Hi! In Graphics settings (global) I have adjusted the Chart Trading Order Lines for child orders to be different colors than normal Trading Order Lines. But the child orders still have same colors as the normal order lines. I have used attached orders when submitting parent and child orders to IB. They show up on charts with association lines, but the child order lines have same color as parent orders. Any ideas? RSy |
Screen Shot 2016-08-24 at 20.39.53.png / V - Attached On 2016-08-24 18:42:57 UTC - Size: 17.04 KB - 294 views |
[2016-08-24 21:10:10] |
Here is the relevant documentation: http://www.sierrachart.com/index.php?page=doc/ChartTradingCustomizingGraphics.php#ChartTradingOrderLineBuyLimitChild The solution to this particular problem when using Interactive Brokers is to disable this option: http://www.sierrachart.com/index.php?page=doc/GlobalTradeSettings.html#UseServerSideOCO Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
