Date/Time: Wed, 23 Sep 2026 10:50:05 +0000
Chart Tab Color
View Count: 2542
| [2016-08-24 16:20:22] |
| User80617 - Posts: 10 |
is it possible to assign a color to a chart tab at the bottom of a chartbook.......example: one chartbook would have 5 charts of different stocks plus one chart of the dji and the dji chart tab would be colored red for easy identification......thanks
| [2016-08-24 16:32:23] |
No, this is not supported.
| [2016-08-24 17:03:49] |
any chance to get it supported....this is a fairly common feature on programs with the ability to have multi-open windows and would certainly be appreciated during the hectic moments during trading.......but I understand if it is to complex to program into sc.....thanks
| [2016-08-24 17:19:10] |
We will put this on our task list, but allow up to one year for it to be done.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-08-24 17:19:56
| [2017-10-03 19:29:21] |
| wwwingman - Posts: 185 |
is it still planned to have the colored tabs ?
| [2017-10-03 19:47:47] |
This is now available: General Settings Window: Color Chart Tabs with Chart Link Number Color (Global Settings >> General Settings >> Charts >> Charts) The coloring is based upon the Chart Linking number. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-10-03 19:47:54
| [2018-09-14 03:19:23] |
| whats1thingnow - Posts: 418 |
can the color be applied also to when we look at the 'CW' menu? right now, we have to look at each row to fine the L:1 to know which is link to what it would be amazing if the chart tabs color can be seen on the 'CW' menu too |
| [2018-09-14 18:49:03] |
Okay we will look into this.
| [2018-10-16 02:22:59] |
any updates? thanks
| [2018-10-16 02:35:13] |
We did actually look into this and we were going to proceed but it was just too involved to do right now: can the color be applied also to when we look at the 'CW' menu?
right now, we have to look at each row to fine the L:1 to know which is link to what it would be amazing if the chart tabs color can be seen on the 'CW' menu too Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-16 02:35:28
| [2019-09-04 19:15:25] |
| ILIM KIRGIZ - Posts: 187 |
As Sierra has better chartbook tab coloring scheme, Is it possible to color the tabs via ACSIL study?
| [2020-05-06 22:14:36] |
| [2020-05-31 03:57:02] |
i have many detached charts and have to look at each row in cw menu to see the links please change cw menu to be colored by link number any updates? thanks Date Time Of Last Edit: 2020-05-31 03:58:09
| [2020-11-17 18:24:00] |
following up on post #10 thank you |
