Date/Time: Fri, 10 Jan 2025 03:48:26 +0000
SC keeps locking up with windows 10
View Count: 810
[2016-08-24 15:58:23]
User338832 - Posts: 4
SC is locking up during the trading day when volume increases on the ES market. I end up having to end the task in order to get the charts back. My Infinity DOM on the same computer does not have any issues. Not sure if their could be an issue with the TransAct SC bridge with windows 10.
[2016-08-24 16:26:44]
So is the Sierra Chart program actually freezing and cannot be interacted with?
We are not aware of any problems like this on Windows 10.
Refer to these 2 help topics:
http://www.sierrachart.com/index.php?page=doc/helpdetails30.html#h30.5 (30.5)
http://www.sierrachart.com/index.php?page=doc/helpdetails30.html#h30.8 (30.8)
The next thing we recommend is to not use your existing Chartbook because maybe there is something about its configuration which is not efficient.
For what that could be, refer to the other subsections in help topic 30:
[2016-08-24 18:09:44]
Zosimus - Posts: 345
User338832 are you using custom studies?
