Date/Time: Fri, 10 Jan 2025 03:58:49 +0000
Service package change to level 3 renewal from level 1?
View Count: 766
[2016-08-24 13:40:25] |
nth - Posts: 46 |
I saw the login message this am re: renewing at level 3 and long term discount. I have over 300 days left at service level 1 which I gather is being discontinued. It is not clear to me if I need to do some now to take advantage of the long term discount or simply wait until it is time to renew? Thank you, nth |
[2016-08-24 15:50:48] |
You do not need to do anything. Your account is set for service package 1 until 2017-06-23
