Date/Time: Fri, 10 Jan 2025 03:52:10 +0000
VOLUME
View Count: 726
[2016-08-24 02:03:58] |
User692217 - Posts: 5 |
Hello. I'm new to the platform and had a volume question I haven't seen addressed in your videos. Is there a reason why volume in Crude shows only in hundreds when my ThinkorSwim platform shows it in the thousands? How do I fox this? I'm using DTN IQFeed. Thanks |
[2016-08-24 02:27:50] |
The volume numbers you see when using IQ Feed are accurate and actual values. We cannot comment about the other service you are using. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
