Date/Time: Mon, 28 Oct 2024 08:57:39 +0000
pen/marker tool
View Count: 2902
[2013-07-22 08:01:52] |
4646ed - Posts: 230 |
why don't you have a pen/marker tool that you can write/draw freehand on the charts?
[2013-07-22 08:05:34] |
A complete freehand drawing would be immensely complicated, inefficient and not workable with the types of charts that Sierra Chart has. Sierra Chart does provide Tools >> Marker to place various types of markers on the chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-02-29 18:40:05] |
User153286 - Posts: 49 |
Why not just a multi-line (continual line draw mode) feature? You already draw lines from point A to point B. Why not from point A, to point B, keep in draw mode to Point C..... to Point N. In a CAD system these types of line drawing tools remain active until the user presses enter to end the point input process. As a consideration, once you now have an array of multiple points, instead of simply connecting point to point, you you can utilize a B-spline algorithm to smooth it out. Having just the point to point to N-point drawing capability would be very helpful to me. I find it strange how you say it would be ineffective. That seems very dependent on how you trade, how you think and how communicate trading ideas with others. |
[2024-02-29 19:34:28] |
John - SC Support - Posts: 35538 |
The Point-to-Point drawing type you describe is available. It is called "Zig Zag" in the Tools menu. Refer to the following: Chart Drawing Tools: Zig-Zag For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-10-01 21:32:29] |
I am not affiliated with this company.... but I suggest to check out Epic Pen
