Date/Time: Fri, 10 Jan 2025 03:57:08 +0000
Version install corrupts Cht. File
View Count: 1116
[2016-08-24 01:07:58]
User299392 - Posts: 216
I just installed the new version and then tried to open my chart book only to find out that a bunch of charts in my 2 chart books were missing.
This has never happened before.
Any take on what is going on here?
[2016-08-24 01:34:34]
When you open the Chartbook are there any error messages displayed in the Window >> Message Log?
[2016-08-24 02:12:50]
Nope; None.
See - a part of it for instance -
HD Request # 92 | Downloading Intraday chart data for F.US.VXJ16 to the file F.US.VXJ16.scid. Service: cfefut | 2016-08-23 22:11:39
HD Request # 92 | Download start Date-Time: 2016-04-20 08:59:44.000 | 2016-08-23 22:11:39
HD Request # 92 | Using server: ds1.sierracharts.com port 10149 | 2016-08-23 22:11:39
Socket (0) | Resolved address ds1.sierracharts.com to IP 8.18.161.135. | 2016-08-23 22:11:39
Socket (125) | Connected. | 2016-08-23 22:11:39
HD Request # 92 | Sending historical data logon request message. | 2016-08-23 22:11:39
HD Request # 92 | Requesting Intraday data. Start Date-Time: 2016-04-20 08:59:44. Record interval: 0. Symbol: VIJ16 | 2016-08-23 22:11:39
HD Request # 92 | Decompressing data. | 2016-08-23 22:11:39
HD Request # 92 | Receiving Intraday data for F.US.VXJ16 starting at 2016-04-20 08:59:44 | 2016-08-23 22:11:39
Socket (125) | Shutdown and closed. | 2016-08-23 22:11:39
The network socket for historical data has been closed. | 2016-08-23 22:11:39
HD Request # 92 | Received 1 record from 2016-04-20 08:59:44 to 2016-04-20 08:59:44 (0.0 seconds) and wrote 0 records for F.US.VXJ16 | 2016-08-23 22:11:39
HD Request # 92 | Intraday download COMPLETE for F.US.VXJ16. Completion time: 0s. Unique request ID: 91 | 2016-08-23 22:11:39
Removed historical data download ID 91 | 2016-08-23 22:11:39
Real-time Intraday chart data file updates started for F.US.VXJ16 | 2016-08-23 22:11:39
Intraday chart data file opened for F.US.VXJ16 | 2016-08-23 22:11:39
HD Request # 93 | Downloading Intraday chart data for F.US.MJNKU16 to the file F.US.MJNKU16.scid. Service: cqg | 2016-08-23 22:11:39
HD Request # 93 | Download start Date-Time: 2016-08-23 21:54:52.000 | 2016-08-23 22:11:39
HD Request # 93 | Using server: ds4.sierracharts.com port 10149 | 2016-08-23 22:11:39
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-08-23 22:11:39
Socket (126) | Connected. | 2016-08-23 22:11:39
HD Request # 93 | Sending historical data logon request message. | 2016-08-23 22:11:39
HD Request # 93 | Requesting Intraday data. Start Date-Time: 2016-08-23 21:54:52. Record interval: 0. Symbol: F.US.MJNKU16 | 2016-08-23 22:11:40
HD Request # 93 | Decompressing data. | 2016-08-23 22:11:40
HD Request # 93 | Receiving Intraday data for F.US.MJNKU16 starting at 2016-08-23 21:54:52 | 2016-08-23 22:11:40
HD Request # 93 | Timestamp of first Intraday data file record written: 2016-08-23 21:54:55 | 2016-08-23 22:11:40
Socket (126) | Shutdown and closed. | 2016-08-23 22:11:40
The network socket for historical data has been closed. | 2016-08-23 22:11:40
HD Request # 93 | Received 2973 records from 2016-08-23 21:54:52 to 2016-08-23 22:11:29 (16.6 minutes) and wrote 2971 records for F.US.MJNKU16 | 2016-08-23 22:11:40
Added 2 Time and Sales records to Intraday data file for F.US.MJNKU16 after download. | 2016-08-23 22:11:40
HD Request # 93 | Intraday download COMPLETE for F.US.MJNKU16. Completion time: 0s. Unique request ID: 92 | 2016-08-23 22:11:40
Removed historical data download ID 92 | 2016-08-23 22:11:40
Real-time Intraday chart data file updates started for F.US.MJNKU16 | 2016-08-23 22:11:40
Intraday chart data file opened for F.US.MJNKU16 | 2016-08-23 22:11:40
Opened cached Intraday file: C:\SierraChart\Data\F.US.MJNKU16.scid | 2016-08-23 22:11:43
[2016-08-24 02:38:54]
Follow the instructions here to access a backup Chartbook:
Chartbooks (Workspaces): Accessing a Backup Chartbook File
[2016-08-24 10:45:35]
Thanks - this helped get back my chart book file.
However, there was an instance when the application just stopped working and Windows had to shut it down.
Do you know a way to know what must have happened without going through so many message log entries?
[2016-08-24 16:28:27]
The Message Log usually is not helpful in this case.
It could be caused by a custom study. Refer to help topic 17.1:
http://www.sierrachart.com/index.php?page=doc/helpdetails17.html#h17.1
[2016-08-24 17:43:18]
So, the application shut down yet again after giving me a Out of Memory error.
Yes, I am using a whole lot of intra day charts. But it was all ok only until recently.
I tried using another instance of SC application to accommodate some of my chartbooks in the second instance but CQG seems like would let me log into just one instance at a time.
I also tried to use 17.1 help topic to decode the dll and that did not help.
What do you think I should do here?
[2016-08-24 19:32:51]
Can you please help with this?
[2016-08-24 20:30:41]
OK so the problem is you are running out of memory.
That is something that actually the Message Log would indicate. It is not a very common condition so we did not consider it.
In this case what you need to do is use additional instances of Sierra Chart. Here is the relevant documentation:
http://www.sierrachart.com/index.php?page=doc/WorkingWithCharts.html#OutOfMemoryCondition
[2016-08-25 19:01:05]
Another instance is cumbersome.
Any ETA on when SC will be a 64-bit application, if at all?
[2016-08-25 20:26:33]
There are currently no active plans for a 64-bit version because if you are working with large amounts of memory it only makes sense to distribute processing load among multiple threads/CPU cores. This can only be done with multiple instances.
