Date/Time: Fri, 10 Jan 2025 03:38:57 +0000
Packages
View Count: 1031
[2016-08-23 14:47:53] |
Ed Meckelborg - Posts: 71 |
I may want to renew or change the package for Sierra Charts. Where do I find the various options? |
[2016-08-23 16:25:43] |
They are documented here: Description of Service Packages and Pricing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-08-23 18:46:34] |
I only see package 3 and 5. Are there others? I also see a discount up to 36 percent. How does one get a better than a 2 percent discount? |
[2016-08-23 20:36:02] |
Only service packages 3 and 5 are available. Your account is already set for a discount of 36 percent. Nothing further you need to do.
