Date/Time: Fri, 10 Jan 2025 04:55:30 +0000
Daily session time for E-mini S&P500 Futures
View Count: 2003
[2016-08-23 14:45:43] |
User378205 - Posts: 28 |
What Session time do I pick to match with average broker's E-mini S&P500 Daily Candle chart?
20160823_234406.png / V - Attached On 2016-08-23 14:45:00 UTC - Size: 34.97 KB - 307 views |
[2016-08-23 17:05:24] |
These are already defined for this particular CQG symbol. Follow the instructions here to apply them to the chart: http://www.sierrachart.com/index.php?page=doc/GlobalSymbolSettings.php#SettingIntradaySessionTimes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-08-23 17:06:02] |
Actually, we are doing some documentation updates on that section. Just give us about 10 minutes.
