Date/Time: Fri, 10 Jan 2025 04:14:02 +0000
Average Daily Range Line
View Count: 889
[2016-08-23 13:15:09] |
User113734 - Posts: 60 |
Hi Sierra, I am looking for a study which may draw a line based on the average daily range, so that if price reaches the line, i'd know the price has already moved a fai distance and a continuation looks less likely. Option to set the ATR length in the study would be ideal. I have seen some ATR studies but none draws a lien in the chart once the ADR pre-determined has been reached. Thanks! |
[2016-08-23 17:26:32] |
All that is available is the Average Daily Range study: https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s347 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
