Date/Time: Fri, 10 Jan 2025 03:55:30 +0000
GraphRegion as a property
View Count: 703
[2016-08-23 12:36:38] |
User754985 - Posts: 109 |
It is often the case that a system calculates an indicator (to be plotted on a separate scale/subgraph) as well as stop levels (to be plotted on price chart). Doing calculations in 2-3 separate studies and applying them on the same chart is cumbersome and inefficient for automated trading. It would be very helpful to also set GraphRegion as a property for a plot, similar to .Name, .DrawStyle, etc |
[2016-08-23 17:33:58] |
This is not anything that we can change.
