Date/Time: Fri, 10 Jan 2025 03:44:09 +0000
Spread study
View Count: 1494
[2016-08-23 08:51:04] |
User113734 - Posts: 60 |
Hi Sierra, Is there any study in SC that may show the current spread I am getting from my broker. As an example, this is what I am looking for. See pict https://gyazo.com/1ba4d88dd45a76d7c2c96dc9dd091b6e (bottom left) I use FX Synergy Trade Panel embedded in SC, but knowing the spread I am getting from my broker, visually, would be of great value. Thanks. |
[2016-08-23 09:59:17] |
Have a look at using the DOM Graph: Trade Menu: Draw DOM Graph on Chart (Trade menu) It should accomplish everything you need. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-08-23 13:09:37] |
Thanks. It does show, however, the spread from FXCM broker(feed i am connected to via SC) instead of my own broker (IC Markets), despite I am using the trade panel study from Pecunia Systems, which is connected to my broker. Any chance i can get my broker's spread in the SC screen? See here https://gyazo.com/efc797dc58ff9a6a1e057c8316be9fee example of what i mean by comparing MT4 (spread on the bottom left) and SC ... Thanks |
[2016-08-23 17:28:11] |
Any chance i can get my broker's spread in the SC screen? No, this is not possible.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-08-23 17:28:35
