Date/Time: Thu, 19 Sep 2024 22:03:23 +0000
Autotrade to 2 brokers for 2 different symbols at the same time
View Count: 1517
[2013-07-22 03:24:43] |
jagoankita - Posts: 24 |
I am looking for a way to send auto trade orders of 2 different symbols for 2 different brokers that comes from one signal in Sierra Chart. Let say the trigger signal using S&P 500 chart that will generate buy order of MSFT to broker A and sell order of GOOG to broker B at the same time. Actually it is possible to do this if there is a way to link cells on spreadsheets from two different copies of Sierra Chart. Thank you. Date Time Of Last Edit: 2013-07-22 03:25:59
[2013-07-22 03:46:50] |
Copies of Sierra Chart are very isolated from each other, but you may be able to write to a file from one custom trading study that another custom trading study in another copy of Sierra Chart can read from and use it as a signal.
[2013-07-22 04:05:22] |
I don't use ACSIL and only spreadsheet for autotrading that I use so far. Is there any such file that I can download, may be from this forum/board? Thanks.
[2013-07-22 18:03:50] |
For what you want to do you really should use ACSIL.
