Date/Time: Fri, 10 Jan 2025 04:32:15 +0000
Memory Usage in version 1448
View Count: 670
[2016-08-22 22:42:00] |
User94740 - Posts: 333 |
I have noticed at least in this version how much memory is now required though the last version according to my memory had used considerably less. Has something changed?
[2016-08-22 23:10:24] |
There is definitely no significant change whatsoever with memory use.
