Date/Time: Fri, 10 Jan 2025 04:18:28 +0000
Usage time ended??
View Count: 782
[2016-08-22 20:38:50] |
User571345 - Posts: 3 |
Not sure why I'm recving this message since I'm using sierra via ampfutures. Also the build I'm running (1261) just tried to auto download and install a recent version. How do I disable this, its never happened before. There should be a prompt for the user to acknowledge before it happens. I tried restarting it...no luck. Not running on a different pc either. Thanx |
[2016-08-22 21:12:11] |
We see you are using Rithmic and there is a mandatory update to the current version when using Rithmic. This is why you see what you do. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
