Date/Time: Fri, 10 Jan 2025 04:24:59 +0000
Thank you and clarification
View Count: 858
[2016-08-22 16:45:36] |
User472677 - Posts: 356 |
Hello, I just wanted to let you guys know that your support is excellent. I fully understand where you are in terms of new features. As a clarification, purpose of posts is to find out if you know a better way that either did not make it in your excellent documentation or I overlooked. Purpose is not a request for a new feature. If a new feature is absolutely necessary, I specifically state that , otherwise my posts are a simple inquiry about existing software. |
[2016-08-22 17:40:23] |
OK thank you.
