Date/Time: Fri, 10 Jan 2025 04:50:34 +0000
Shading parallel lines or adding interior levels on rectangle tool?
View Count: 711
[2016-08-22 16:05:09] |
User341584 - Posts: 44 |
Is it possible to shade parallel lines tool or add interior lines to the rectangle tool?
[2016-08-22 17:07:42] |
No. This is not supported.
