Date/Time: Fri, 10 Jan 2025 17:40:36 +0000
urgent ameritrade connection
View Count: 1373
[2016-08-22 15:39:08]
User472677 - Posts: 356
This morning repeatedly running into problems with ameritrade connection. Ameritrade says it is a sierra chart issue. I will appreciate any insights you can provide.
From the log
HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.37. | 2016-08-22 11:26:32
HTTPS connection to ameritrade02.streamer.com:443 (76) | Connected. | 2016-08-22 11:26:32
HTTPS connection to ameritrade02.streamer.com:443 (76) | Starting TLS 1.0 connection. | 2016-08-22 11:26:32
HTTPS connection to ameritrade02.streamer.com:443 (76) | SSL connection established. | 2016-08-22 11:26:32
TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 09-2 | 2016-08-22 11:26:32
HTTPS connection to ameritrade02.streamer.com:443 (76) | SSL connection closed by remote side. | 2016-08-22 11:28:15
HTTPS connection to ameritrade02.streamer.com:443 (76) | Connection gracefully closed by remote side. | 2016-08-22 11:28:15
HTTPS connection to ameritrade02.streamer.com:443 (76) | SSL object has been freed. SSL state is now disconnected. | 2016-08-22 11:28:15
HTTPS connection to ameritrade02.streamer.com:443 (76) | Shutdown and closed. | 2016-08-22 11:28:15
TD Ameritrade | Streamer request completed unexpectedly. Request ID: 28. | 2016-08-22 11:28:15
TD Ameritrade | Streamer request #29 initiated. | 2016-08-22 11:28:17
HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.37. | 2016-08-22 11:28:17
HTTPS connection to ameritrade02.streamer.com:443 (78) | Connected. | 2016-08-22 11:28:17
HTTPS connection to ameritrade02.streamer.com:443 (78) | Starting TLS 1.0 connection. | 2016-08-22 11:28:17
HTTPS connection to ameritrade02.streamer.com:443 (78) | SSL connection established. | 2016-08-22 11:28:17
TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 09-2 | 2016-08-22 11:28:17
HTTPS connection to ameritrade02.streamer.com:443 (78) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-08-22 11:28:19
HTTPS connection to ameritrade02.streamer.com:443 (78) | SSL shutdown indicates not able to send 'close notify'. | 2016-08-22 11:28:19
HTTPS connection to ameritrade02.streamer.com:443 (78) | SSL has been shut down. | 2016-08-22 11:28:19
HTTPS connection to ameritrade02.streamer.com:443 (78) | SSL object has been freed. SSL state is now disconnected. | 2016-08-22 11:28:19
HTTPS connection to ameritrade02.streamer.com:443 (78) | Shutdown and closed. | 2016-08-22 11:28:19
TD Ameritrade | Streamer request completed unexpectedly. Request ID: 29. | 2016-08-22 11:28:19
TD Ameritrade | Streamer request #30 initiated. | 2016-08-22 11:28:21
HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.37. | 2016-08-22 11:28:21
HTTPS connection to ameritrade02.streamer.com:443 (79) | Connected. | 2016-08-22 11:28:21
HTTPS connection to ameritrade02.streamer.com:443 (79) | Starting TLS 1.0 connection. | 2016-08-22 11:28:21
HTTPS connection to ameritrade02.streamer.com:443 (79) | SSL connection established. | 2016-08-22 11:28:22
TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 09-2 | 2016-08-22 11:28:22
[2016-08-22 17:02:54]
Do not trust anything that TD Ameritrade is saying.
They are not qualified to say the things that they are.
This indicates a connectivity problem to the TD Ameritrade server and that could be anywhere.
Including a problem with the server itself.
There is not anything we can do to help with this.
If you require stock data, then use the Sierra Chart Exchange Data Feed:
http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php
[2016-08-22 17:45:02]
sc feed will not solve problem of putting trading orders.
Here is a specific question for you after speaking to Ameritrade again. Is Sierra limiting the number of simultaneous connections from different sierra instances to ameritrade?
According to ameritrade rep, ameritrade does not limit number of connections but sierra may be doing so.
If I leave only one sierra instance open, problem goes away.
[2016-08-22 17:55:07]
Sierra Chart places no restrictions at all with real-time connections to external services.
However, TD Ameritrade does have a limitation to our knowledge of one connection per username.
[2016-08-22 18:21:16]
thx
let me go back to them.
[2016-08-22 18:32:57]
narrowed down to an ameritrade server issue. ameritrade has many servers and they allow 3rd party programs to switch servers. is there a setting in sierra to switch server?
not asking for a new feature. just asking for info on software as it exists.
thx
[2016-08-22 21:09:32]
No, there is not a way to switch servers. We do not even know what the other server addresses are. We are only aware of one address for the TD Ameritrade streamer.
[2016-08-23 01:21:10]
thx. I have other addresses but hopefully problem can be solved without you doing anything.
No action is needed on your part at this time.
[2016-08-23 02:20:54]
If these are standard listed addresses we can add them to a list that you can choose from. That is not too much effort on our part.
Date Time Of Last Edit: 2016-09-16 05:41:29
[2016-09-15 21:53:37]
These addresses work for a different program. Please see if they work with sc
216.105.251.37
216.105.251.38
216.105.251.39
[2016-09-16 05:42:48]
We will allow the server address to be specified for the Ameritrade streamer.
[2016-09-17 11:14:54]
We have hidden the prior post. We will rethink this.
[2016-09-30 16:24:04]
Just following up to see how you are coming along on this update.
Thx
[2016-09-30 17:28:08]
This was released about a week ago.
Update Sierra Chart to the latest Prerelease:
http://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate
The setting is Global Settings >> Data/Trade Service Settings >> Streamer Address Override.
It needs to start with https://
However, you really need to use a better data feed and we recommend the Sierra Chart Exchange Data Feed. We cannot continue to provide help with TD Ameritrade data problems which we have no control over.
